[Gdal-dev] Re: primary key on Virtual Spatial Data (ODBC)
Bart van den Eijnden BEN at Syncera-ITSolutions.NL
Mon Nov 14 04:26:41 EST 2005
After some debugging I found out that the Microsoft Access ODBC driver does not support the SQLPrimaryKeys function which is used to determine the primary key.
[Microsoft][ODBC Driver Manager] Driver does not support this function
So, anyway, time to convince some people to switch to a decent database .....
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG  DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
An embedded message was scrubbed...
From: "Bart van den Eijnden" <BEN at Syncera-ITSolutions.NL>
Subject: primary key on Virtual Spatial Data (ODBC)
Date: Wed, 09 Nov 2005 13:02:29 +0100
Url: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051114/b626b0d1/attachment.mht
