[Gdal-dev] Oracle-bindings
Bart van den Eijnden BEN at Syncera-ITSolutions.NL
Wed Nov 16 09:37:07 EST 2005
Are you able to connect with sqlplus?
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG  DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Stephan Holl <sholl at gmx.net> 11/16/05 3:26 PM >>>
Hello Bart,
On Wed, 16 Nov 2005 14:20:05 +0100 "Bart van den Eijnden"
<BEN at Syncera-ITSolutions.NL> wrote:
> Hi Stephan,
> AFAIK Oracle accepts connections from within the same network by
> default. Is port 1521 not blocked by a firewall by any chance? Can
> you telnet to it? I had problems with the Windows XP firewall when
> trying to connect to an Oracle database in my internal network.
I can telnet to the oracle-port 1521. Everything should be OK.
> If you have a full Oracle client installed, there is a utility called
> tnsping which you can use to try and ping the database server.
No I do not have the full client installed. Perhaps I should grab them
from oracle and retry.
> Otherwise, try and use a tnsnames.ora file. Make sure you have the
> environment variable TNS_ADMIN set to the directory in which the
> tnsnames.ora file resides. You then connect using user/pwd at tnsname.
> Example tnsnames.ora file:
> PORCL =
>   (DESCRIPTION =
>     (ADDRESS_LIST =
>       (ADDRESS = (PROTOCOL = TCP)(HOST = P0676)(PORT = 1521))
>     (CONNECT_DATA =
>       (SERVER = DEDICATED)
>       (SERVICE_NAME = PORCL)
OK, thanks for the pointer, but still no luck.
export TNS_ADMIN=/home/holl/software/oracle
cat /home/holl/software/oracle/tnsnames.ora
ORACLESP =
  (DESCRIPTION =
    (ADDRESS_LIST =
      (ADDRESS = (PROTOCOL = TCP)(HOST = 192.168.1.4)(PORT =
1521)) )
    (CONNECT_DATA =
      (SERVICE_NAME = oraclesp)
ogrinfo OCI:user/pw at oraclesp
FAILURE:
Unable to open datasource `OCI:user/pw at oraclesp' with the
following drivers. -> ESRI Shapefile
  -> UK .NTF
  -> SDTS
  -> TIGER
  -> S57
  -> MapInfo File
  -> DGN
  -> VRT
  -> AVCBin
  -> REC
  -> Memory
  -> CSV
  -> GML
  -> SQLite
  -> ODBC
  -> PGeo
  -> OGDI
  -> PostgreSQL
  -> OCI
  -> GRASS
Best
	Stephan
