[Gdal-dev] specifying FID in connection string
Tue Nov 22 09:33:13 EST 2005
On 11/22/05, Bart van den Eijnden <BEN at syncera-itsolutions.nl> wrote:
> Hi list,
> there seem to be occassional problems with the detection of a primary key using ODBC, I have experienced it using Access and now Oracle. Would it be an idea to be able to optionally specify the FID column in the connection string? I think that would solve a lot of issues.
> Using my Oracle view I now get:
> OGR_ODBC: Table V_BIS_LOC has no identified FID column.
> I also tried using the geometry table by itself, and still no FID column could be recognized. Then I tried specifying a primary key constraint on the view with Oracle SQL, but still no FID recognition.
> What do people think about this? For my applications it is quite crucial that a primary key is recognized, since otherwise Mapserver queries won't run reliably.
Bart,
A few days ago I added a mechanism to specify the name of
the FID column using the ODBC_OGR_FID configuration variable.
So, in a mapfile you could put:
CONFIG "ODBC_OGR_FID" "ID"
However, this is a global setting, not layer specific.  If this
won't do the trick, let me know and I will add a way to specify
the FID along with the tablename in the datasource name.
Best regards,
