[Gdal-dev] ECW build questions on Windows
Tue Nov 22 18:48:23 EST 2005
On 11/22/05, Yewondwossen Assefa <assefa at dmsolutions.ca> wrote:
> Hi there,
>   To build gdal with ECW on windows, I tried to use the sdk windows
> binaries provided at ermapper. The problem I had was that the sdk
> provided does not have all the header files necessary to build with gdal
> (I was missing to start with NCSJP2File.h).  These header files are
> available if I download a package with the source code. The "anoying"
> thing is that the package of source code and the pacage of binaries are
> not the same version (at least I could not locate one on the ain
> download page).
>   My question is that how do people usually do this on wondows ? Is the
> only choice builing the package locally ?
Assefa,
Put this way, I think you will need to try building the
ECW SDK from source.
Best regards,
