[Gdal-dev] compiling gdal with ECW capabilities
FX GAMOY fx.gamoy at geomatika.fr
Mon Nov 28 13:56:08 EST 2005
hello Vladimir,
thanks for your post,
but my problem is that i cannot run ./configure --with-ecw=/usr/local
configure return :
checking for libNCSEcw.so or libecwj2... configure: error: not found
in /usr/local/lib or /usr/local/bin.
and
the file libNCSEcw.so is in /usr/local/lib
i dont' know  why configure don't see it
best regards
fx
Le Jeudi 24 Novembre 2005 18:59, Vladimir Guzmán a écrit :
> fx:
> I had some problems compiling gdal under amd64 too.
> The way I 'fixed' it was manually editing the configure file, and
> looking for the line which was causing the problem.
> Next, almost always, the trick was to change the references to
> /usr/local/lib or /usr/lib to /usr/local/lib64 or /usr/lib64.
> Hope that helps,
> Vladimir Ilich Guzmán R.
> http://maintask.com
> FX GAMOY escribió:
> >Hello everybody
> >i ve successfully compiled ecw sdk 3.3 package on my amd64 box (gentoo
> >distrib) and installed the librairy and source code on /usr/local
> >When i try to configure gdal --with-ecw=/usr/local , gdal is not able to
> > see the ECW librairy.
> >I ve read some posts talking about this but i can't understand the
> > solution..
> >"I think the include files need to be in /usr/local/include.  I think
> >the issue is that some include files were not normally considered
> >public but are needed by GDAL.  As a workaround I would
> >suggest copying /usr/local/Source/include/* to /usr/local/include.
> >Did you unpack your ECW SDK right in /usr/local?  That seems
> >pretty messy"
> >i did the copy of my home/source/libecwj2/include/* into
> > /usr/local/include all the libNCSE* are in /usr/local/lib
> >but gdal don't see those files...
> >Do i have to copy all the directory libecwj2-3.3 in usr/local and get
> >/usr/local/libecwj2-3.3/*  ??
> >I think i ve missed something... :-)
> >thanks
> >best regards
> >fx
> >_______________________________________________
> >Gdal-dev mailing list
> >Gdal-dev at lists.maptools.org
> >http://lists.maptools.org/mailman/listinfo/gdal-dev
FX GAMOY
06 87 39 32 03
Géomatika
Technopole de la Côte Basque
Pavillon Izarbel
64210 BIDART
http://www.geomatika.fr/
http://www.pagesbasques.com/
