[Gdal-dev] CreateCopy into buffer
Ivan Mjartan ivan.mjartan at geovap.cz
Tue Nov 29 09:24:54 EST 2005
Hi list,
I am writing function in C++ witch on input get large raster and return small sub window of the input raster in BitMap (*.BMP file). The sub window is never larger then 1000*1000px.
The code looks like:
hDriver = GetGDALDriverManager()->GetDriverByName("BMP");
hDataset = GDALOpenShared( pszSrcFilename, GA_ReadOnly );
poVDS = new VRTDataset(xsize, ysize);
nBandCount = GDALGetRasterCount( hDataset );
for( i = 0; i < nBandCount; i++ )
    VRTSourcedRasterBand   *poVRTBand;
    GDALRasterBand  *poSrcBand;
    GDALDataType    eBandType;
    poSrcBand = ((GDALDataset *)hDataset)->GetRasterBand(i+1);
    eBandType = poSrcBand->GetRasterDataType();
    poVDS->AddBand( eBandType, NULL );
    poVRTBand = (VRTSourcedRasterBand *) poVDS->GetRasterBand( i+1 );
    poVRTBand->AddSimpleSource( poSrcBand,x, y, xsize, ysize,0, 0, xsize, ysize );
    poVRTBand->CopyCommonInfoFrom( poSrcBand );
hOutDS = GDALCreateCopy( hDriver,"c:\\CsharpTest\\temp\\cut.bmp", (GDALDatasetH) poVDS,FALSE, NULL, NULL, NULL );
Than I am calling this function from C# .Net application and I need result (in example case cut.bmp) in byte array.
It is possible use CreateCopy with out disk writing operation and return result in byte array?
 thanks ivan
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051129/715b3f80/attachment.html
