[Gdal-dev] GDAL changes affecting GRASS?
Tue Nov 29 19:55:15 EST 2005
On 11/29/05, William Kyngesburye <woklist at kyngchaos.com> wrote:
> I've been having a problem with GRASS lately, and it seems to be
> related to GDAL.  I have a GRASS bug open for it: #3585.  Noone has
> provided any help so far.
> The key trigger combination is: GDAL 1.3.1 (and 1.3.0, possibly the
> beta), GRASS 6.0/6.1, and built with GCC 3.3 on Mac OS 10.3.  There
> is no problem building with GCC 4 on Mac OS 10.4, or with GCC 3.3 and
> GDAL 1.2.6.  Or if I build GRASS without GDAL.  Yes, the GCC 3.3 and
> GCC 4 builds each have their dependencies built with the
> corresponding GCC version.
> The problem is that I get bus errors in a few module - specifically,
> simple general commands such as g.remove, g.rename and g.copy (but
> not others, like g.list).
> So, the question for GDAL - what changed from 1.2.6 to 1.3.x that
> might affect GRASS this way and only for GCC 3.3-built.
William,
I can't think of any obvious reason for this.  I think you will need
to dig deeper before we can do anything about this.
Best regards,
