[Gdal-dev] linking problems with MrSID library
William Kyngesburye woklist at kyngchaos.com
Tue Oct 4 10:49:20 EDT 2005
On Oct 4, 2005, at 12:56 AM, Bill Binko wrote:
> Alright, after much banter, and a few curses, Frank and I seem to have
> found a way to make MrSID work cleanly without having to change
> between
> GCC 3.x compilers.  I have not tested this with 4.x, but it just might
> work.
> Only two things need to change:
> 1) You can't use libtool.  (If a libtool person wants to get with me
> offline we can workout what's needed.)  When you run configure add
> --without-libtool.
> 2) After configure, edit GDALmake.opt and add the full path to the
> appropriate c++ library for your version of MrSID's SDW (for my
> version 5,
> it's /usr/lib/libstdc++.so.5) to the end of your LIBS variable.
> Build and install, all should be right with the world.
No go.  No missing symbols, but tons of multiple definitions
warnings, that eventually cause it to fail.
ld: warning multiple definitions of symbol ___gxx_personality_v0
/usr/lib/gcc/darwin/3.3/libstdc++.a(eh_personality.o) private
external definition of ___gxx_personality_v0 in section (__TEXT,__text)
/usr/lib/gcc/powerpc-apple-darwin8/4.0.0/libstdc++.dylib(single
module) definition of ___gxx_personality_v0
[many, many more]
ld: multiple definitions of symbol
__ZStplIcSt11char_traitsIcESaIcEESbIT_T0_T1_ES3_RKS6_
/usr/lib/gcc/darwin/3.3/libstdc++.a(string-inst.o) private external
definition of __ZStplIcSt11char_traitsIcESaIcEESbIT_T0_T1_ES3_RKS6_
/usr/bin/libtool: internal link edit command failed
Maybe it doesn't like mixing the static and dynamic libraries?
(there's no choice there - static for the old, dynamic for the new)
Note: using libtool and adding the GCC 3.3 libstdc++ to LIBS also
works for me (with the same multi defs problem), it's not stripping
out what I add to LIBS, and it IS using LIBS.  At least without
libtool, I could play with linker options to try to get rid of the
multi defs problem, but the few options I tried didn't help.
I guess I'll just continue to wait for LizardTech to get crackin on
an update.  The conversion program they provide in the DSDK still
works in Mac OS 10.4, so at least I have some sort of conversion
option from MrSID.
> Go back to your default build: the one that ended up with only linker
> errors.  Go ahead and build: you'll fail at link time on the
> applications.
It has always failed at the library link step.  Never got to the
applications.
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
