Fix for building perl bindings was Re: [Gdal-dev] Newbie with OGRPerl bindings
Matt Foster Matthew.Foster at noaa.gov
Fri Oct 7 11:18:16 EDT 2005
Sorry, I guess I didn't include the exact error message...
gcc -c  -I../../gcore -I../../alg -I../../ogr -I../../port -D_REENTRANT
-D_GNU_SOURCE -DTHREADS_HAVE_PIDS -DDEBUGGING -fno-strict-aliasing
-I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64
-I/usr/include/gdbm -O2 -g -pipe -march=i386 -mcpu=i686   -DVERSION=\"\"
-DXS_VERSION=\"\" -fPIC
"-I/usr/lib/perl5/5.8.0/i386-linux-thread-multi/CORE"   gdal_wrap.cpp
gdal_wrap.cpp: In function `void _wrap_Dataset_GetGCPs(PerlInterpreter*,
CV*)':
gdal_wrap.cpp:4877: `SWIG_NewPointerObj' undeclared (first use this
function)
gdal_wrap.cpp:4877: (Each undeclared identifier is reported only once
for each
   function it appears in.)
make[1]: *** [gdal_wrap.o] Error 1
Matt
Ethan Alpert wrote:
>What's the error? Was it in a previous post?
>-e
>-----Original Message-----
>From: gdal-dev-bounces at lists.maptools.org
>[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Matt Foster
>Sent: Friday, October 07, 2005 8:50 AM
>To: Kevin Ruland
>Cc: gdal-dev at lists.maptools.org
>Subject: Re: Fix for building perl bindings was Re: [Gdal-dev] Newbie
>Kevin,
>OK, I started fresh with a 'make clean', and then did these steps...
>./configure --with-netcdf=<path to netcdf>
>make
>make install
>This went fine, and everything is installed under /usr/local.  Then
>things go bad...
>cd swig/perl
>make
>make fails trying to compile gdal_wrap.cpp with SWIG_NewPointerObj being
>undeclared.  I tried adding the -L/usr/local/lib to the Makefile.PL, as
>you suggested (even though /usr/local is default), and even added
>/usr/local/lib to LD_LIBRARY_PATH, and it fails in the same place with
>the same error.
>Matt
>Kevin Ruland wrote:
>>Matt,
>>There appears to be some problems with 'make install' in the perl
>>bindings - there are some work-arounds for it and if you use --prefix
>>things get a little harder.
>>If you decide to install gdal in either /usr/local or /usr/ (this is
>>the case when you don't use --prefix in ./configure), the best option
>>is to not use the --with-perl option, but instead do this:
>>./configure --normal-configure-options  (omit the --with-perl option)
>>make make install
>>cd swig/perl
>>make
>>make install
>>This should install the perl module correctly.
>>If you desire to install gdal in a non-default location you will need
>>to hack the swig/perl/Makefile.PL script to get the build to function
>>correctly.
>>./configure --prefix=myprefix --normal-configure-options (omit the
>>--with-perl option) make
>>make install
>>cd swig/perl
>>-- edit the Makefile.PL and change all the lines with LIB => "-lgdal"
>to
>>LIB => '-Lmyprefix/lib -lgdal'
>>make
>>make install
>>We are currently working on a platform independent way to make this
>>more automatic.  It should make it into cvs shorly, and in the 1.3.2
>>release.  Until then we'll have to struggle a little more.
>>Best of luck.
>>Kevin
>>Matt Foster wrote:
>>>Ari Jolma wrote:
>>>>Matt Foster kirjoitti:
>>>>>Would anyone have a sample code snippet they'd be willing to share,
>>>>>showing how to create a simple point shapefile with the OGR Perl
>>>>>binding?
>>>>look at  the test.pl in swig/perl, it creates and opens raster and
>>>>vector data files
>>>>Ari
>>>Ari,
>>>Something is wrong with my installation here.  When I tried to run
>>>test.pl it said that it could find a loadable module for gdalconst,
>>>despite the fact that gdalconst.pm is in my @INC list.  I think in my
>>>effort yesterday to get around the compilation failure of
>>>gdal_wrap.cpp, I fouled up the installation.  I think I need to step
>>>back, and start fresh.
>>>I worked on the assumption yesterday that to get the Perl bindings
>>>built and installed that I would do these steps from the gdal base
>>>directory (I also use netCDF)...
>>>./configure --with-netcdf=<path to netcdf> --with-perl
>>>make
>>>make install
>>>Is that incorrect?  If those are indeed the right steps, then I need
>>>to figure out why gdal_wrap.cpp fails to build.
>>>Matt
>>_______________________________________________
>>Gdal-dev mailing list
>>Gdal-dev at lists.maptools.org
>>http://lists.maptools.org/mailman/listinfo/gdal-dev
"Those who would sacrifice essential liberties for a little
temporary safety deserve neither liberty nor safety."
-- Benjamin Franklin
