[Gdal-dev] Revised patch for reading nos files
Karl Palsson lists at tweak.net.au
Sat Oct 15 15:00:38 EDT 2005
Ok, so only a moron would submit a diff that segfaults, and expect anyone to pay attention, so I've cleaned up my act, read some more documentation of the api available from gdal/core, and have revised my diff that adds support for reading GCPs for .NOS files from the corresponding .GEO files.
It doesn't segfault, it uses CPL* routines, instead of str* functions, it doesn't have FIXMEs in it anymore.
The patch is against the stock 1.3.1 source.
Cheers,
Karl P
> Attached is a diff against 1.3.1, that adds support for gdal to get the GCP information
> from the .GEO files that accompany a .NOS file.
> .NOS files are just like BSB files, except that instead of having a plain text header
> section containging projection and control point information, it comes in a corresponding
> .geo file.
> The patch is pretty dirty, (gdalinfo will print out the correct information, and then
> segfault)  mostly because I'm using the "wrong" tools to do the string manipulation.
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051015/beb650d3/bsb-nos-mark2.obj
