[Gdal-dev] Comparing Barely-Different SpatialRef Objects with .IsSame
Sat Oct 15 18:11:23 EDT 2005
On 10/14/05, Christopher Michaelis <cmichaelis at happysquirrel.com> wrote:
> Hi there,
> I'm trying to compare two proj4 strings by loading each one into an
> OGRSpatialReference object using .ImportFromProj4(), then comparing them
> using .IsSame().
> The problem that's arising is that the two are just barely off
> (.0000000001 off on the y_0 parameter). Therefore, .IsSame() is
> returning false.
> So, my question for the crowd is, how can I detect this condition and
> actually catch these two as equivalent?
> The two strings in question are:
> "+proj=lcc +lat_1=38.33333333333334 +lat_2=39.83333333333334
> +lat_0=37.66666666666666 +lon_0=-122 +x_0=2000000 +y_0=500000.0000000001
> +ellps=GRS80 +datum=NAD83 +to_meter=0.3048006096012192 +no_defs"
> +lat_0=37.66666666666666 +lon_0=-122 +x_0=2000000 +y_0=500000.0000000002
> Any thoughts? BTW, I'm using GDAL 1.3.0.
Chris,
This is just one of a variety of limitations of
OGRSpatialReference::IsSame().   If you want to make serious
use of the method it will need some parameter type sensitive
epsilon testing as well as lots of other logic.
Short of rolling up your sleeves and implementing such logic
I have no advice.
Best regards,
