[Gdal-dev] gdal-grass plugin rpm
Otto Dassau dassau at gdf-hannover.de
Wed Oct 26 11:43:07 EDT 2005
Am Mittwoch, 26. Oktober 2005 17:28 schrieb Frank Warmerdam:
> On 10/26/05, Otto Dassau <dassau at gdf-hannover.de> wrote:
> > ok, it happens in gdal itself, but building the gdal rpm package I also
> > defined /usr as prefix, so how can I change this and make gdal look
> > in /usr/lib/gdalplugins?
> Otto,
> Are you saying that GDAL was configured with --prefix=/usr but
> the cpl_config.h has a GDAL_PREFIX of "/usr/local"?  That
> shouldn't happen.  Could you confirm that before I start digging
> into the configure magic?
yes, I can confirm this - unfortunately. I will send you my spec files
thanks a lot
