[Gdal-dev] GML support
Clay, Bruce bclay at ball.com
Fri Sep 30 08:23:35 EDT 2005
While working on a task to convert ESRI shape files to ASCII then back
to binary I noticed there is support in GDAL for converting the geometry
to GML.  I did not see anything to convert the feature data to GML did I
miss something or is it not available yet?
I am currently working with version 1.20.  I know there are later
versions but I use several different packages and had stop upgrading
every time a new release came out for code stability reasons.
Is there more GML support in the current version?
Has anyone written a shape to GML and GML to shape application yet?
Bruce
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20050930/b566d94f/attachment.html
