[Gdal-dev] Python C API version mismatch
Sean Gillies sgillies at frii.com
Tue Apr 4 12:12:54 EDT 2006
On Apr 4, 2006, at 9:09 AM, John Cartwright wrote:
> Hello All,
> Can someone tell me what I might have done wrong in compiling gdal
> 1.3.1 on linux? I get the following error upon importing the gdal
> module:
> /data1/contrib/lib/python2.4/gdal.py:191: RuntimeWarning: Python C
> API version mismatch for module _gdal: This Python has API version
> 1012, module _gdal has version1011.
> I'm using python2.4.2, and these are my configure options:
> ./configure --prefix=/data1/contrib/gdal-1.3.1 \
> --with-png=internal \
> --with-libtiff=internal --with-geotiff=internal \
> --with-libz=internal --with-jpeg=internal --with-gif=internal \
> --with-pg=/usr/bin/pg_config \
> --with-mysql=/usr/bin/mysql_config \
> --with-oci=/usr/lib/oracle/10.2.0.1/client \
> --with-geos=/data1/contrib/geos-2.2.1/bin/geos-config \
> --with-pymoddir=/data1/contrib/lib/python2.4
> Thanks!
> -- john
John,
Is it possible that your pymoddir is not on your Python path, and
that you're importing an older gdal.py?
I think your configure should probably have
   --with-pymoddir=/data1/contrib/lib/python2.4/site-packages
just for the sake of keeping site-packages like gdal in the right place.
Sean
Sean Gillies
http://zcologia.com
