[Gdal-dev] Python C API version mismatch
    John Cartwright
    John.C.Cartwright at noaa.gov
    Tue Apr  4 15:59:43 EDT 2006
Thanks Sean, that helps.  Seems like my underlying problem is that
configure is picking up the first python executable in my path (the
older 2.2.3).  I don't see a way to specify the python executable to
use, do you know a better solution other than mainipulating my
environment for the configure/build process?
-- john
Sean Gillies wrote:
> On Apr 4, 2006, at 9:09 AM, John Cartwright wrote:
>> Hello All,
>> Can someone tell me what I might have done wrong in compiling gdal
>> 1.3.1 on linux? I get the following error upon importing the gdal
>> module:
>> /data1/contrib/lib/python2.4/gdal.py:191: RuntimeWarning: Python C
>> API version mismatch for module _gdal: This Python has API version
>> 1012, module _gdal has version1011.
>> I'm using python2.4.2, and these are my configure options:
>> ./configure --prefix=/data1/contrib/gdal-1.3.1 \
>> --with-png=internal \
>> --with-libtiff=internal --with-geotiff=internal \
>> --with-libz=internal --with-jpeg=internal --with-gif=internal \
>> --with-pg=/usr/bin/pg_config \
>> --with-mysql=/usr/bin/mysql_config \
>> --with-oci=/usr/lib/oracle/10.2.0.1/client \
>> --with-geos=/data1/contrib/geos-2.2.1/bin/geos-config \
>> --with-pymoddir=/data1/contrib/lib/python2.4
>> Thanks!
>> -- john
> John,
> Is it possible that your pymoddir is not on your Python path, and
> that you're importing an older gdal.py?
> I think your configure should probably have
>   --with-pymoddir=/data1/contrib/lib/python2.4/site-packages
> just for the sake of keeping site-packages like gdal in the right place.
> Sean
> Sean Gillies
> http://zcologia.com
