[Gdal-dev] How to use GetLockedBlockRef
Reiner Beck r.beck at m4com.de
Tue Apr 4 12:30:18 EDT 2006
Hello list,
Hello Frank,
after upgrading to GDAL 1.3.1 (from 1.2.6) the method
GDALRasterBand::GetBlockRef() is no longer available. It has been
replaced by GDALRasterBand::GetLockedBlockRef().
Simply replacing the call with GDALRasterBand::GetLockedBlockRef() does
work somehow. However, for large images the process will allocate the
whole memory of the system up to a degree where it becomes unusable.
I fixed that by releasing each band after accessing the tile data with
"block->DropLock()". This seems to work.
Question: Is this the supposed way to use the block cache? If not, a
short example would help ...
The documentation for GDALRasterBand still contains references to
GetBlockRef. To avoid confusion I propose to remove or change that.
Further, I have the impression that some public member functions in
GDALRasterBlock shouldn't really be public, or am I supposed to use e.g.
Internalize()?
Cheers
Reiner
