[Gdal-dev] Question about gdal_rasterize
Wed Apr 12 11:30:40 EDT 2006
Guillaume HUBY wrote:
> Hello,
> I have a question about gdal_rasterize. I'm using
>>> gdal_rasterize --version
> GDAL 1.3.1.0, FWTools 1.0.0b2, released 2006/03/30
> I achieved to rasterized an ESRI polygon shapefile on some Geotiff raster.
> The pixels was burned when their center was inside the polygon. I would like
> to know if there is a way to burn pixels which are entirely inside polygons.
> I mean that the four corners of pixels are inside without intersecting
> polygon.
> I would be very grateful if someone could answer this question.
Guillaume,
There is no support for this in the GDAL rasterizer.  You could try and
fiddle with the low level to allow this but it could be pretty tricky.
Another alternative would be to rasterize four rasters all offset by
half a pixel in the four directions, and then merge them - only setting
the target pixel if all our offsets were rasterized.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
