[Gdal-dev] geotiff-format and arcview 3.2
Helmut Kudrnovsky hellik at web.de
Wed Dec 6 12:23:37 EST 2006
hi,
i've converted an arcinfo-grid to a geotiff-file with fwtool 1.10.
here the gdalinfo for the file
Driver: GTiff/GeoTIFF
Size is 19484, 14376
Coordinate System is:
PROJCS["Austria_BMN_MGI_M28",
    GEOGCS["GCS_MGI",
        DATUM["unknown",
            SPHEROID["unnamed",6377397.155,299.1528128000009]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",10.33333333333333],
    PARAMETER["scale_factor",1],
    PARAMETER["false_easting",150000],
    PARAMETER["false_northing",-5000000],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]]]
Origin = (303113.879154104680000,204201.999388290600000)
Pixel Size = (2.499960860736726,-2.499960860736726)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  COMPRESSION=LZW
Corner Coordinates:
Upper Left  (  303113.879,  204201.999) ( 12d20'42.96"E, 46d57'34.90"N)
Lower Left  (  303113.879,  168262.562) ( 12d19'59.71"E, 46d38'11.63"N)
Upper Right (  351823.117,  204201.999) ( 12d59'4.90"E, 46d56'48.00"N)
Lower Right (  351823.117,  168262.562) ( 12d58'7.94"E, 46d37'25.25"N)
Center      (  327468.498,  186232.281) ( 12d39'28.97"E, 46d47'31.55"N)
Band 1 Block=256x256 Type=Byte, ColorInterp=Gray
  NoData Value=255
  Overviews: 4869x3592, 2433x1795, 1215x896, 606x447, 302x222, 150x110, 74x54
if i load this file in arcgis 9.1, everything is ok and i can see the geotiff-file in a correct way and all colors are correct.
i can load this file also in arcview 3.2, but in the colormap there seems to be only value 0 available and so the geotiff has only one color.
maybe are there any experiences out there if arcview 3.2 can't handle geotiff's? or maybe some hints for solve the problem?
greetings from austria and thanks in advance
helli
_______________________________________________________________________
Viren-Scan für Ihren PC! Jetzt für jeden. Sofort, online und kostenlos.
Gleich testen! http://www.pc-sicherheit.web.de/freescan/?mc=022222
