[Gdal-dev] LinearRing and GetGeometryType
Wed Feb 8 22:20:46 EST 2006
On 2/8/06, Didrik Pinte <dpinte at itae.be> wrote:
> Hi,
> I'm using the Python interface to OGR, but the problem will be
> encountered in all the languages
> As a subclass of OGRLineString, when calling geometry.GetGeometryType()
> on a OGRLinearRing object, it returns ogr.wkbLineString type and not an
> ogr.wkbLinearRing type.
> It this behaviour normal ? or should it be modified ?
> What should be the best fix for this problem ?
> [1] implement GetGeometryType in OGRLinearString ?
> [2] if the current behaviour is the right way to do it, just fix it in
> my ogr.py file redefining the GetGeometryType for the LinearRing
> objects ?
Didrik,
The OGRLinearRing used to return wkbLinearRing (a
nonstandard made up code of mine) but I removed
it again a while ago.  I'm not really sure why.  If you
want to distinguish linear rings from line strings you
can check the geometry name (call GetGeometryName()).
Best regards,
