[Gdal-dev] extra qualification 'FITRasterBand::' on member 'FITRasterBand'
Fri Feb 17 12:41:17 EST 2006
Mike Leahy wrote:
> Hello list,
> I'm wondering if anyone might recognize the errors I'm getting below
> when I try to compile gdal.  I'm currently running FC5 test 2...I'm
> pretty sure I got the same version to compile fine on FC4, so maybe this
> is an issue with gcc-4.1.0 that is the current release for FC5?  At any
> rate, regardless of what options I include in the configuration (i.e.,
> disabling/internalizing as many options as possible), I get the same
> result.  I don't see anything recent in the list that suggests anyone
> else has the same problem...
> Any ideas?  Should I just forget about getting this to work on FC5/gcc4
> for now?
> Thanks in advance for any suggestions,
> Mike
> fitdataset.cpp:177: error: extra qualification 'FITRasterBand::' on
> fitdataset.cpp: In static member function 'static GDALDataset*
Mike,
Change:
     FITRasterBand::FITRasterBand( FITDataset *, int );
To:
I have committed the same change in CVS.   Let me know if you
run into other problems.
Best regards,
