[Gdal-dev] extra qualification 'FITRasterBand::' on member 'FITRasterBand'
Mike Leahy mgleahy at golden.net
Fri Feb 17 18:52:14 EST 2006
Hello again,
I did in fact find some new problems with 1.3.1, so I switched to the
CVS, and that seems to have addressed alot of the stuff I pointed out
earlier, so I guess you can ignore my previous message.  However, now I
get some new issues, which look somewhat similar, but I'm not sure how I
should go about fixing these - I tried imitating the previous solution,
but it I'm not having any luck:
make[2]: Entering directory `/data/mapserver/gdal/frmts/fits'
/bin/sh ../../libtool --mode=compile g++ -Wall  -O2   -I../../port
-I../../gcore -I../../alg -I../../ogr -I../../ogr/ogrsf_frmts
-DOGR_ENABLED -c -o ../o/fitsdataset.o fitsdataset.cpp
  g++ -Wall -O2 -I../../port -I../../gcore -I../../alg -I../../ogr
-I../../ogr/ogrsf_frmts -DOGR_ENABLED -c fitsdataset.cpp  -fPIC -DPIC -o
../o/.libs/fitsdataset.o
fitsdataset.cpp:104:20: error: fitsio.h: No such file or directory
fitsdataset.cpp:120: error: ISO C++ forbids declaration of 'fitsfile'
with no type
fitsdataset.cpp:120: error: expected ';' before '*' token
fitsdataset.cpp:130: error: 'fitsfile' has not been declared
fitsdataset.cpp: In member function 'virtual CPLErr
FITSRasterBand::IReadBlock(int, int, void*)':
fitsdataset.cpp:193: error: 'fitsfile' was not declared in this scope
fitsdataset.cpp:193: error: 'hFITS' was not declared in this scope
fitsdataset.cpp:193: error: 'class FITSDataset' has no member named 'hFITS'
fitsdataset.cpp:218: error: 'fits_read_img' was not declared in this scope
FITSRasterBand::IWriteBlock(int, int, void*)':
fitsdataset.cpp:237: error: 'fitsfile' was not declared in this scope
fitsdataset.cpp:237: error: 'hFITS' was not declared in this scope
fitsdataset.cpp:237: error: 'class FITSDataset' has no member named 'hFITS'
fitsdataset.cpp:250: error: 'fits_write_img' was not declared in this scope
fitsdataset.cpp:256: error: 'NUM_OVERFLOW' was not declared in this scope
fitsdataset.cpp: In constructor 'FITSDataset::FITSDataset()':
fitsdataset.cpp:303: error: 'hFITS' was not declared in this scope
fitsdataset.cpp: In destructor 'virtual FITSDataset::~FITSDataset()':
fitsdataset.cpp:313: error: 'hFITS' was not declared in this scope
fitsdataset.cpp:317: error: 'fits_movabs_hdu' was not declared in this scope
fitsdataset.cpp:318: error: 'fits_write_key_longwarn' was not declared
in this scope
fitsdataset.cpp:351: error: 'fits_update_key_longstr' was not declared
in this scope
fitsdataset.cpp:372: error: 'fits_close_file' was not declared in this scope
fitsdataset.cpp: At global scope:
fitsdataset.cpp:382: error: 'CPLErr FITSDataset::Init' is not a static
member of 'class FITSDataset'
fitsdataset.cpp:382: error: 'fitsfile' was not declared in this scope
fitsdataset.cpp:382: error: 'hFITS_' was not declared in this scope
fitsdataset.cpp:382: error: expected primary-expression before 'bool'
fitsdataset.cpp:382: error: initializer expression list treated as
compound expression
fitsdataset.cpp:382: error: expected ',' or ';' before '{' token
make[2]: *** [../o/fitsdataset.o] Error 1
make[2]: Leaving directory `/data/mapserver/gdal/frmts/fits'
make[1]: *** [fits-install-obj] Error 2
make[1]: Leaving directory `/data/mapserver/gdal/frmts'
make: *** [frmts-target] Error 2
Mike
Frank Warmerdam wrote:
> Mike Leahy wrote:
>> Hello list,
>> I'm wondering if anyone might recognize the errors I'm getting below
>> when I try to compile gdal.  I'm currently running FC5 test 2...I'm
>> pretty sure I got the same version to compile fine on FC4, so maybe
>> this is an issue with gcc-4.1.0 that is the current release for FC5?
>> At any rate, regardless of what options I include in the configuration
>> (i.e., disabling/internalizing as many options as possible), I get the
>> same result.  I don't see anything recent in the list that suggests
>> anyone else has the same problem...
>> Any ideas?  Should I just forget about getting this to work on
>> FC5/gcc4 for now?
>> Thanks in advance for any suggestions,
>> Mike
>> fitdataset.cpp:177: error: extra qualification 'FITRasterBand::' on
>> fitdataset.cpp: In static member function 'static GDALDataset*
> Mike,
> Change:
>     FITRasterBand::FITRasterBand( FITDataset *, int );
> To:
> I have committed the same change in CVS.   Let me know if you
> run into other problems.
> Best regards,
