[Gdal-dev] GCPs to geo transform
Thu Feb 23 16:16:41 EST 2006
Antoine Hue wrote:
> Hello,
> I was wondering if it is possible to compute the geo transform given a
> set of GCPs without warping the image?
> That's what is being done in the osgTerrain  library I am using, it is
> warping the image to a geotiff as soon as there are GCPs without
> checking if the source and destination CS are the same.
> Thanks a lot for the GDAL, it is doing a lot for me.
Antoine,
Perhaps the GDALGCPsToGeoTransform() function would be of some use to you.
It computes an approximate geotransform from a set of GCPs.
However, there is no way to utilize this from the existing commandline
tools.  So it would only be useful if you were scripting or programming.
Best regards,
