[Gdal-dev] ogr2ogr Point not Point ZM
Alex Mandel tech_dev at wildintellect.com
Thu Jan 5 15:13:54 EST 2006
Frank Warmerdam wrote:
> On 1/5/06, Alex Mandel <tech_dev at wildintellect.com> wrote:
>>When I do:
>>ogr2ogr -update -append two.shp one -nln two one -nlt POINT
>>The appended file, which has no points to begin with(but is basically
>>the same as the original with a couple of extra fields and the points
>>removed) ends up with geometry of type POINT ZM(3D). I need it to simply
>>be POINT(2D), no z or m values. ArcGIS software handles POINT and POINT
>>ZM very  differently so they are two distinctly different options.
>>I thought I had solved it by adding the -nlt POINT portion but it turns
>>out that didn't have any effect.
> Alex,
> If two.shp already exists, then whether it is POINT or POINTZM is
> already established.  How are you creating it?
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
I made two.shp by taking one.shp opening it in ArcMap, removing the
points, adding fields and then saving the changes.
If I check the properties on two.shp & one.shp in ArcCatalog before I do
the append, under GEOMETRY it says
GEOMETRY Type Point
Contains Z values No
Contains M values No
After the append, two.shp says
GEOMETRY Type Point
Contains Z values Yes
Contains M values Yes
It wouldn't surprise me if there is some ESRI monkey business in the
background that I don't know about when I go to look at the file in Arc
after the append.
Alex
Sorry if this posts twice - wierd email glitch.
