[Gdal-dev] NOAA 14 geocoding?
Markus Neteler neteler at itc.it
Mon Jan 30 08:01:28 EST 2006
I have ordered a coulpe of AVHRR images from CLASS archives
(http://www.class.noaa.gov) for Northern Italy:
ftp://ftp.class.noaa.gov/A2585871/
(each image 3-4MB).
To geocode them, I used gdalwarp but the images didn't
cover Northern Italy after geocoding (they appear East of
the Caspian Sea):
# apply GCPs with thin plate spline transformer
gdalwarp -tps -of HFA -t_srs "EPSG:4326" -co COMPRESS=YES \
  NSS.LHRR.NJ.D99174.S1236.E1248.B2308484.GC.L1261491 \
  NSS.LHRR.NJ.D99174.S1236.E1248.B2308484.GC.L1261491.img
The resulting images are also almost North-South oriented which
is unlikely.
I used the "generate map" feature of CLASS to verify the
position before ordering.
Is it possible that the NOAA 14 format differs?
Markus
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
