[Gdal-dev] Wrong geometry type detected
Chapman, Martin MChapman at sanz.com
Mon Jan 30 15:46:05 EST 2006
If that doesn't work just call flattenTo2D() before using the geometry
and that will make sure it's 2D.
Martin
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Frank
Warmerdam
Sent: Monday, January 30, 2006 12:12 PM
To: Petteri Packalen
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] Wrong geometry type detected
On 1/30/06, Petteri Packalen <packalen at cs.joensuu.fi> wrote:
> Frank et al.
> I observed that the OGR recognizes incorrect point type in some
occasions.
> When the real point type is wkbPoint25D but the Z-value is exactly
zero
> getGeometryType() returns wkbPoint. This happens at least when the
> shapefile driver is used (GDAL 1.2.6.0).
> I cannot see this to be preferred logic, or do I miss something?
Petteri,
There was a major overhaul of OGR geometry in the
early fall of 2005 to carry along coordinate dimension
information explicitly.   That overhaul should fix the particular
problem you are seeing.
I would encourage you to upgrad eto GDAL 1.3.1.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
