[Gdal-dev] gdal/ogr python issues after re-compile
Dylan Beaudette dylan.beaudette at gmail.com
Mon Jan 30 19:54:06 EST 2006
This morning I had a working copy of the GDAL python modules.
After a re-compile with postgresql enabled this time, I found the following
problem:
a python script using the .Buffer() method from ogr.py causes a segfault.
All of my python stuff is installed via debian packages, while GDAL and
PostgreSQL are done via source code.
re-compiling with the --without-pg option, i find that the python program
still segfaults!
any thoughts on what could be messed up with my OGR python modules? I have
confirmed that i can in fact use ogr2ogr, so it must be something with the
python stuff.
thanks in advance,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
