[Gdal-dev] Cookie cutting shapefiles in OGR
Chapman, Martin MChapman at sanz.com
Tue Jul 4 16:33:13 EDT 2006
Mateusz,
Thanks for the information.
Martin
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Mateusz Loskot
Sent: Tuesday, July 04, 2006 1:53 PM
To: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] Cookie cutting shapefiles in OGR
Matthew Perry wrote:
> On 7/4/06, Chapman, Martin <MChapman at sanz.com> wrote:
>> 2.  If you actually want to clip intersecting geometries and
>> reshape them to your cookie cutter geometry then you need to use a
>> library like GPC (http://www.cs.man.ac.uk/~toby/alan/software/ ).
>> ......  If Frank W. is reading this posting I would urge him to
>> consider including GPC as part of OGR since it's small, fast,
>> powerful, and easy to use.
> The GPC licensing might make that tricky:
> "You may not use this software, in whole or in part, in support of
> any commercial product without the express consent of the author."
> This would conflict with GDAL/OGR's license quite a bit.
Matthew is right.
GPC is a kind of double-licensed software, similarly to QT.
It's free of charge for non-commercial projects.
So, I think GPC could be supported as a plugin or extension
but not included in GDAL for every user, e.g. for commercial users.
In my last company I worked for, we were using GPC with .NET apps
and we had to buy it.
Good news is that there is no price set, but you can pay as much as you
can (at least year ago when we were buying GPC).
Cheers
Mateusz Loskot
http://mateusz.loskot.net
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
