[Gdal-dev] Reducing geotiff colors to a standard LUT
Jed O. Kaplan jed.kaplan at ips.unibe.ch
Tue Jul 4 17:52:45 EDT 2006
Hello all,
I have a series of geotiff files that are 8-bit paletted pseudocolor
images. Unfortunately each separate image file has a different color
table, though they are a sort of DRGs so the original scans have
approximately all the same colors.
I would like to convert all the images to have a standard color
table, so that, e.g., I can merge the files into a single image,
perform GIS operations, etc.
Is there any way using GDAL tools or the API that I can give all of
my individual images the same color table?  The image files are large
(ca. 2000x3000 pixels), but I can convert them temporarily to full
color rgb images and then reduce the colors.  I have a standard color
table in another geotiff file.
I have tried to do this using the imagemagick tool: convert -map
<file> <infile> <outfile> but this process is impossibly slow.
Any suggestions for (standardized, semi-automated) color reduction
for DRG's would be much appreciated.
Thanks,
Jed Kaplan
