[Gdal-dev] ArcView binary raster support
Clay, Bruce bclay at ball.com
Wed Jul 5 08:31:07 EDT 2006
While it may not help for the current task, I heard at a recent
developers conference that ESRI is going to build GDAL support into an
upcoming release.  That may overcome the need for ESRI raster format
support.
Bruce
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Frank
Warmerdam
Sent: Tuesday, July 04, 2006 10:35 PM
To: Matt Wilkie
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] ArcView binary raster support
Matt Wilkie wrote:
> Hi Vincent and interested coders,
>> Would it be possible to add support to gdal for native ArcView raster
>>  files, including other datatypes than simple ints, and (basic)
>> projection support?
>> BTW I send this message to the list rather than directly to Frank
>> because maybe others are interested too and willing to share the cost
> I think the ESRI format most likely to be recognised and utilised
across
> the widest range of versions of ArcView & ArcGIS is ArcInfo GRID (the
> 'aig' driver to gdal).
> I'm not in a position to offer sharing of costs but I can certainly
> provide GRID rasters across the range of int types and projections for
> anyone who is interested in developing an AIG write driver for gdal
and
> needs sample data.
Vincent / Matt,
I imagine Arc/Info Binary Grids are the most natural way to provide
raster support for ArcView.  Unfortunately, a fairly valiant effort on
my part to implement write support for this format a few years ago
failed.
The format is undocumented, and while I was able to deduce enough
information
about it to read it effectively, I was never able to write valid files.
I
am not terribly inclined to revisit this issue, though someone keen
could
start from the existing file format definition (and perhaps I have some
code)
and try to implement it.
Another format that is fairly well supported by ArcView is the .HDR
labelled
BIL.  I have done some improvements in recent months to this driver and
you may find it suitable for some purposes.  However, it does not seem
to be a very expressive way of describing the data type (float vs.
integer
for instance) which can be a problem.
I am open to other advice on good ways of exporting raster data in a
form
that is useful in ArcView.
As Vincent mentioned, things should be better with ArcGIS (and hopefully
getting better with each new version of ArcGIS).
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush    | President OSGF,
http://osgeo.org
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
