[Gdal-dev] gdalwarp and gdal_translate question
chantain greer chantain.c.greer at hotmail.com
Fri Jul 7 13:46:00 EDT 2006
I wanted to ask is there a techniqal difference between the way gdalwarp and
gdal_translate scales the resolution of a file in pixels.
gdalwarp uses the -ts option to set output file size in pixels and lines but
gdal_translate uses -outsize to set the size of the output file.
I wanted to find out if the output file would be the same if you used either
technique.
Thank you.
