[Gdal-dev] definition in the EPSG file
Zhonghai Wang zhonghaiw at gmail.com
Wed Jul 12 06:19:39 EDT 2006
Hi guys,
I noticed that some definitions for the EPSG codes in the epsg file is not
so clear, which means there are no parameters for the epsg codes, for
example:
# ETRS89 / UTM zone 32N
<25832> +proj=utm +zone=32 +ellps=GRS80 +units=m +no_defs  <>
the EPSG code for this one is 25832, but there are no other parameters any
more, such as longitude, latitude, central meridian, false northing, false
easting.....
and also this one:
# NAD83(HARN)
<4152> +proj=longlat +ellps=GRS80 +no_defs  <>
if the epsg code is defined like this, does it mean that the the EPSG code
is not valid for use or is not defined?
a little bit confused.
kind regards
zhonghai
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060712/28e83d48/attachment.html
