[Gdal-dev] Problem with HDF4 samples
Daniele Romagnoli dany.geotools at gmail.com
Thu Jul 13 06:08:15 EDT 2006
Hi list,
I'm trying to exploit the HDF4 files provided in the GDAL samples download
area:
http://dl.maptools.org/dl/gdal/data/hdf4 or
ftp://ftp.remotesensing.org/gdal/data/hdf4
However, when trying to open them (as an instance, by using gdalinfo in
order to check available datasets), I get this error:
ERROR 4:
`d:\DatiPlugin\MO36MW14.chlor_MODIS.ADD2001089.004.2002186190207.hdf'
not recognised as a supported file format.
Someone can help me?
If the 2 files aren't valid samples, where I can find some working HDF4
sample to use with GDAL?
Thx a lot.
Best Regards,
Daniele
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060713/03c7d0d5/attachment.html
