[Gdal-dev] linking proj4
Chris Calloway cbc at unc.edu
Thu Jun 1 11:59:39 EDT 2006
I've done *some* looking around, and figure I'm at the point where I
should ask...
Considering the gdal configure feature:
--with-static-proj4
described as:
"Compile with PROJ.4 statically"
Does this mean proj is automatically dynamically linked (if present in
the library path or by ld.so.conf, etc.) by GDAL, or that the only
possible linking of proj by GDAL is static?
Sincerely,
Chris Calloway
http://www.seacoos.org
office: 17-6 Venable Hall   phone: (919) 962-4323
mail: Campus Box #3300, UNC-CH, Chapel Hill, NC 27599
