[Gdal-dev] gdalwarp Transparency Question
Wed Jun 7 21:57:49 EDT 2006
Reinaldo Escada Chohfi wrote:
> Frank,
> I have a question about the usage of
> -scrnodata /value [value...]/:  Set nodata masking values for input
> bands (different values can be supplied for each band). If more than one
> value is supplied all values should be quoted to keep them together as a
> single operating system argument.
> It's not clear to me what's written on the second sentence.  How would I
> specify to set masking for the following RGB values 0 0 0, 0 0 17, 0 0
> 22, 0 22 0?
> Would it be --scrnodata "0 0 0" "0 0 17" "0 0 22" "0 22 0"?
Reinaldo,
Gdalwarp only supports a single nodata value.  The verbage is trying to
indicate that you would need to quote the argument if you are providing
a tuple.  So '-srcnodata 0' is fine (and indicates 0 in all bands is nodata)
but if you wanted to indicate that red=0, green=0, blue=17 was nodata you
would need '-srcnodata "0 0 17"'.
But gdalwarp just doesn't support having more than one nodata tuple as
you apparently want to do.  Sorry.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
