[Gdal-dev] GDALColorEntry? GDT_CInt16?
Wed Mar 8 16:56:04 EST 2006
Marc A. Lepage wrote:
> After reading the docs, I remain confused about the exact types (and
> ranges) of data in a few cases.
> A GDALColorEntry has 4 shorts representing (e.g.) R, G, B, A. Are they
> storing values from 0-255, or 0-32767? (I am assuming they are signed.)
> When I get a value (say c1 representing red), how should I be reading
> its value?
The red, green, blue and alpha values are in the range 0 to 255.  A
short type was used because I was concerned that some color models
needed a larger type.  However, not having pursued other color models
it hasn't been an issue.
> For complex GDALDataType GDT_CInt16, is that a single 16-bit quantity
> which is to be read as two 8-bit quantities? Or is it two 16-bit
> quantities? Are they signed or unsigned?
GDT_CInt16 consists of two 16bit values, one for the "real" and one
for the "imaginary" component.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
