[Gdal-dev] gdalwarp custom reprojections
Fri Mar 24 14:24:18 EST 2006
kgrootendorst at baird.com wrote:
> Listers,
> First, I'm new to the list - is there anyway to search the list
> postings?  I don't want to be 'that guy' who posts a question that's
> been posted a million times before...
> Second, I'm trying to reproject a tif image using gdalwarp.  Specially,
> from UTM Zone 21N WGS 84 (epsg:32621) to Barbados National Grid
> (epsg:21292).  I used the following code in  FWTools1.0.0a5:    gdalwarp
> -s_srs epsg:32621 -t_srs epsg:21292 -co "TFW=YES"
> d:\Barbados\QB2005w.tif d:\Barbados\QB2005w_BNG.tif
>  I suspect that I may need to do a custom transformation using x, y, z
> shift values (I have these values).  Is there any way to include these
> parameters in my gdalwarp code above?
Kevin,
It looks like my current definition for EPSG:21292 is:
   +proj=tmerc +lat_0=13.17638888888889 +lon_0=-59.55972222222222
           +k=0.999999 +x_0=30000 +y_0=75000 +ellps=clrk80
           +towgs84=31.95,300.99,419.19,0,0,0,0 +units=m +no_defs
If the provided towgs84 values seem inappropriate you can given the
explicit PROJ.4 string you would like on the commandline.
eg.
gdalwarp -s_srs epsg:32621 -t_srs '+proj=tmerc ... +towgs84=yourvalues ...' ...
Just make sure you use the whole definition from above, replacing the
+towgs84= section with your values.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
