[Gdal-dev] gdal_translate image grow
Norman Barker nbarker at rsinc.com
Thu Mar 30 08:22:26 EST 2006
I am using gdal_translate as the 'engine' behind mod_python as a very
simple WMS (so that I can prototype a few ideas before putting them into
MapServer), everything works fine until I specify a BBOX such that the
extents are outside that of the requested image.  This corresponds to
the -projwin option of gdal_translate, executing this I then get an
error "-srcwin falls outside of raster size".
Is there a way to grow the output image and fill in the missing data?
So for example
gdal_translate -not_strict -OF PNG -a_nodata 0 -projwin -180 90 180 -90
-outsize 836 654 inputimage outputimage
would give an output image with world extents, and somewhere in this
image would be the inputimage
Alternatively is there a way to do this with the python bindings or any
other utility.  I like gdal_translate since it does the conversion and
sampling in one go!
thanks
Norman
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Luc Van Asch
Sent: Wednesday, March 15, 2006 8:05 AM
To: gdal-dev at lists.maptools.org
Cc: Ouns Kissiyar; Joeri Robbrecht; Bart Cosyn
Subject: [Gdal-dev] GDAL and Intergraph .cmp files
Dear List,
We are using Integraph software (Geomedia, Orthopro...) in our
organization.
Intergraph uses by default a compressed raster file format for it's
raster data (extension .cmp).
Does anyone knows if there's have been done some work to support this
format in de GDAL
environment?
Thank you all in advance for any tips or help,
Luc
Luc Van Asch
Informaticus
Lijn Geografische Data Infrastructuur - Faciliteiten
VLM-Ondersteunend Centrum GIS Vlaanderen
Gebroeders Van Eyckstraat 16
9000 Gent
Alg. tel: 09/261.52.00
Direct tel: 09/261.52.15
Mobile: 0499/258025
fax: 09/261.52.99
Mailto:luc.vanasch at vlm.be <blocked::blocked::mailto:luc.vanasch at vlm.be>
http://www.gisvlaanderen.be
<blocked::blocked::http://www.gisvlaanderen.be/>
VLM disclaimer :
http://www.vlm.be/Help/disclaimer.htm
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060330/6e22d17b/attachment.html
