[Gdal-dev] Potential thrashing on band 1?
Fri May 5 10:07:02 EDT 2006
Ben Discoe wrote:
> Thanks Frank.  In case anyone else sees the thrash message, i made it go
> away by increasing the cache with GDALSetCacheMax().  In this case, default
> cache size was 10MB but my row of tiles was 12MB.
> Curiously, gdalinfo reports a block of size 4093x21.
Ben,
Well, presumably that is the physical strip size in the TIFF file.  If
you wanted to verify this, you could use tiffinfo.exe on the file (from
FWTools for instance).
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
