[Gdal-dev] Numeric/NumPy and gdalnumeric.py
Didrik Pinte dpinte at itae.be
Thu May 11 04:17:54 EDT 2006
Le jeudi 11 mai 2006 à 03:22 +0200, Mateusz Łoskot a écrit :
> Mateusz Łoskot wrote:
> > So, the main issue is about transition gdalnumeric.py to use new NumPy
> > module. As I talked with Frank on the #gdal channel, the idea is to not
> > transit to NumPy completely, but also support old Numeric package.
> Howard suggested on the #gdal to solve it in following way:
> - NG Python bindings support NumPy package
> - old traditional Python bindings support old Numeric package
> Personally, I like this approach.
> What do you think?
That's a good idea.
I will test the ng-python module with my problematic scripts and see
what kind of problems i'm facing.
Little question : i've installed swigwin 1.3.29 and modified the gdal
nmake.opt to point to the swig executable. Do I have to change something
else in order to get the -ng-python bindings functionnal ?
Didrik
Name: not available
Desc: Ceci est une partie de message
	=?ISO-8859-1?Q?num=E9riquement?= =?ISO-8859-1?Q?_sign=E9e?=
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060511/d10567fe/attachment.bin
