[Gdal-dev] writing RPC data in NITF format?
Sarah Mulholland SARAH.M.MULHOLLAND at saic.com
Thu May 11 11:55:49 EDT 2006
I have a NITF image and RPC data in a separate
file.  I need to embed the RPC data in the NITF
file.  I see that there's a GDALExtractRPCInfo
function.  Would it be straightforward to create a
GDALInsertRPCInfo so that I can perform the
following steps:
1. populate a GDALRPCInfo object with the RPC values
2. read the NITF image into a GDAL data set
3. insert the RPC information
4. write the result to a NITF file
Is this straightforward to do?
Thanks in advance,
Sarah
