[Gdal-dev] ogrinfo: Unable to initialize ODBC connection
Christian Wilmes C.Wilmes at gmx.de
Fri May 19 02:17:12 EDT 2006
Hi Frank,
you are right it sounds like a ODBC problem, but in my opinion it could not be one because I'm using the same driver in a C#-program and there I connect succesfully to the database.
Best Regards
Christian
-------- Original-Nachricht --------
Betreff: Re: [Gdal-dev] ogrinfo: Unable to initialize ODBC connection
Datum: Thu, 18 May 2006 14:50:09 -0400
Von: Frank Warmerdam <warmerdam at pobox.com>
An: Christian Wilmes <C.Wilmes at gmx.de>
> Christian Wilmes wrote:
> > Hi All,
> > I try to connect to a PostgreSQL-Database over ODBC. When typing the
> command ogrinfo ODBC.ovf I get the following errors:
> > ERROR 4: Update access not supported for VRT datasources.
> Christian,
> The above can be disregarded.
> > ERROR 1: Unable to initialize ODBC connection to DSN for
> user/pass at Postgre,
> > Specified driver could not be laodet due to system error 182
> (PostgreSQL+).
> The second line of the above sounds like a message from the ODBC system,
> not
> OGR and presumably represents some real problem initializing the postgres
> ODBC driver.  I don't see any problem with the ovf file itself.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGF, http://osgeo.org
Bis zu 70% Ihrer Onlinekosten sparen: GMX SmartSurfer!
      Kostenlos downloaden: http://www.gmx.net/de/go/smartsurfer
