[Gdal-dev] ogr gml reader needs an update
Peter Rushforth peter.rushforth at gmail.com
Wed May 24 22:04:22 EDT 2006
Hi Frank,
I have made the following updates:
gmlreader.h
-added m_nWidth class member to GMLPropertyDefn
-added getter and setter for m_nWidth member
gmlpropertydefn.cpp
-modified member function AnalysePropertyValue() to set the m_szWidth
member via SetWidth method in the case of a string value
gmlfeatureclass.cpp
-added code to set property definition width member to value of Width
element found in .gfs file
The system does create the correctly populated Width element in the .gfs file,
but the m_szWidth member is ignored by the ogr2ogr system when it comes
to creating the output layer.  Could you point out where I need to look to make
that change please?
Cheers,
Peter
 * $Id: gmlfeatureclass.cpp,v 1.5 2003/09/11 20:01:21 warmerda Exp $
 * Project:  GML Reader
 * Purpose:  Implementation of GMLFeatureClass.
 * Author:   Frank Warmerdam, warmerdam at pobox.com
 * Copyright (c) 2002, Frank Warmerdam
 * Permission is hereby granted, free of charge, to any person obtaining a
 * copy of this software and associated documentation files (the "Software"),
 * to deal in the Software without restriction, including without limitation
 * the rights to use, copy, modify, merge, publish, distribute, sublicense,
 * and/or sell copies of the Software, and to permit persons to whom the
 * Software is furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included
 * in all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
 * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
 * DEALINGS IN THE SOFTWARE.
 * $Log: gmlfeatureclass.cpp,v $
 * Revision 1.5  2003/09/11 20:01:21  warmerda
 * removed unused variable
 * Revision 1.4  2003/05/21 03:48:35  warmerda
 * Expand tabs
 * Revision 1.3  2002/03/06 20:07:35  warmerda
 * added tracking of extents, feature count and extrainfo
 * Revision 1.2  2002/01/24 17:37:33  warmerda
 * added to/from XML support
 * Revision 1.1  2002/01/04 19:46:30  warmerda
 * New
#include "gmlreader.h"
#include "cpl_conv.h"
/*                          GMLFeatureClass()                           */
GMLFeatureClass::GMLFeatureClass( const char *pszName )
    m_pszName = CPLStrdup( pszName );
    m_pszElementName = NULL;
    m_pszGeometryElement = NULL;
    m_nPropertyCount = 0;
    m_papoProperty = NULL;
    m_bSchemaLocked = FALSE;
    m_pszExtraInfo = NULL;
    m_bHaveExtents = FALSE;
    m_nFeatureCount = -1; // unknown
/*                          ~GMLFeatureClass()                          */
GMLFeatureClass::~GMLFeatureClass()
    CPLFree( m_pszName );
    CPLFree( m_pszElementName );
    CPLFree( m_pszGeometryElement );
    for( int i = 0; i < m_nPropertyCount; i++ )
        delete m_papoProperty[i];
    CPLFree( m_papoProperty );
/*                           GetProperty(int)                           */
GMLPropertyDefn *GMLFeatureClass::GetProperty( int iIndex ) const
    if( iIndex < 0 || iIndex >= m_nPropertyCount )
        return NULL;
    else
        return m_papoProperty[iIndex];
/*                          GetPropertyIndex()                          */
int GMLFeatureClass::GetPropertyIndex( const char *pszName ) const
        if( EQUAL(pszName,m_papoProperty[i]->GetName()) )
            return i;
    return -1;
/*                            AddProperty()                             */
int GMLFeatureClass::AddProperty( GMLPropertyDefn *poDefn )
    CPLAssert( GetProperty(poDefn->GetName()) == NULL );
    m_nPropertyCount++;
    m_papoProperty = (GMLPropertyDefn **)
        CPLRealloc( m_papoProperty, sizeof(void*) * m_nPropertyCount );
    m_papoProperty[m_nPropertyCount-1] = poDefn;
    return m_nPropertyCount-1;
/*                           SetElementName()                           */
void GMLFeatureClass::SetElementName( const char *pszElementName )
    m_pszElementName = CPLStrdup( pszElementName );
/*                           GetElementName()                           */
const char *GMLFeatureClass::GetElementName() const
    if( m_pszElementName == NULL )
        return m_pszName;
    else
        return m_pszElementName;
/*                         SetGeometryElement()                         */
void GMLFeatureClass::SetGeometryElement( const char *pszElement )
    m_pszGeometryElement = CPLStrdup( pszElement );
/*                          GetFeatureCount()                           */
int GMLFeatureClass::GetFeatureCount()
    return m_nFeatureCount;
/*                          SetFeatureCount()                           */
void GMLFeatureClass::SetFeatureCount( int nNewCount )
    m_nFeatureCount = nNewCount;
/*                            GetExtraInfo()                            */
const char *GMLFeatureClass::GetExtraInfo()
    return m_pszExtraInfo;
/*                            SetExtraInfo()                            */
void GMLFeatureClass::SetExtraInfo( const char *pszExtraInfo )
    CPLFree( m_pszExtraInfo );
    if( pszExtraInfo != NULL )
        m_pszExtraInfo = CPLStrdup( pszExtraInfo );
/*                             SetExtents()                             */
void GMLFeatureClass::SetExtents( double dfXMin, double dfXMax,
                                  double dfYMin, double dfYMax )
    m_dfXMin = dfXMin;
    m_dfXMax = dfXMax;
    m_dfYMin = dfYMin;
    m_dfYMax = dfYMax;
    m_bHaveExtents = TRUE;
/*                             GetExtents()                             */
int GMLFeatureClass::GetExtents( double *pdfXMin, double *pdfXMax,
                                 double *pdfYMin, double *pdfYMax )
    if( m_bHaveExtents )
        *pdfXMin = m_dfXMin;
        *pdfXMax = m_dfXMax;
        *pdfYMin = m_dfYMin;
        *pdfYMax = m_dfYMax;
    return m_bHaveExtents;
/*                         InitializeFromXML()                          */
int GMLFeatureClass::InitializeFromXML( CPLXMLNode *psRoot )
/*      Do some rudimentary checking that this is a well formed         */
/*      node.                                                           */
    if( psRoot == NULL
        || psRoot->eType != CXT_Element
        || !EQUAL(psRoot->pszValue,"GMLFeatureClass") )
        CPLError( CE_Failure, CPLE_AppDefined,
                  "GMLFeatureClass::InitializeFromXML() called on %s node!",
                  psRoot->pszValue );
        return FALSE;
    if( CPLGetXMLValue( psRoot, "Name", NULL ) == NULL )
                  "GMLFeatureClass has no <Name> element." );
        return FALSE;
/*      Collect base info.                                              */
    m_pszName = CPLStrdup( CPLGetXMLValue( psRoot, "Name", NULL ) );
    SetElementName( CPLGetXMLValue( psRoot, "ElementPath", m_pszName ) );
    const char *pszGPath = CPLGetXMLValue( psRoot, "GeometryElementPath", "" );
    if( strlen( pszGPath ) > 0 )
        SetGeometryElement( pszGPath );
/*      Collect dataset specific info.                                  */
    CPLXMLNode *psDSI = CPLGetXMLNode( psRoot, "DatasetSpecificInfo" );
    if( psDSI != NULL )
        const char *pszValue;
        pszValue = CPLGetXMLValue( psDSI, "FeatureCount", NULL );
        if( pszValue != NULL )
            SetFeatureCount( atoi(pszValue) );
        // Eventually we should support XML subtrees.
        pszValue = CPLGetXMLValue( psDSI, "ExtraInfo", NULL );
            SetExtraInfo( pszValue );
        if( CPLGetXMLValue( psDSI, "ExtentXMin", NULL ) != NULL
            && CPLGetXMLValue( psDSI, "ExtentXMax", NULL ) != NULL
            && CPLGetXMLValue( psDSI, "ExtentYMin", NULL ) != NULL
            && CPLGetXMLValue( psDSI, "ExtentYMax", NULL ) != NULL )
            SetExtents( atof(CPLGetXMLValue( psDSI, "ExtentXMin", "0.0" )),
                        atof(CPLGetXMLValue( psDSI, "ExtentXMax", "0.0" )),
                        atof(CPLGetXMLValue( psDSI, "ExtentYMin", "0.0" )),
                        atof(CPLGetXMLValue( psDSI, "ExtentYMax", "0.0" )) );
/*      Collect property definitions.                                   */
    for( CPLXMLNode *psThis = psRoot->psChild;
         psThis != NULL; psThis = psThis->psNext )
        if( EQUAL(psThis->pszValue, "PropertyDefn") )
            const char *pszName = CPLGetXMLValue( psThis, "Name", NULL );
            const char *pszType = CPLGetXMLValue( psThis, "Type", "Untyped" );
            GMLPropertyDefn *poPDefn;
            if( pszName == NULL )
                          "GMLFeatureClass %s has a PropertyDefn without a <Name>..",
                          m_pszName );
                return FALSE;
            poPDefn = new GMLPropertyDefn(
                pszName, CPLGetXMLValue( psThis, "ElementPath", NULL ) );
            if( EQUAL(pszType,"Untyped") )
                poPDefn->SetType( GMLPT_Untyped );
            else if( EQUAL(pszType,"String") )
                poPDefn->SetType( GMLPT_String );
                poPDefn->SetWidth( atoi( CPLGetXMLValue( psThis, "Width", "0" ) ) );
            else if( EQUAL(pszType,"Integer") )
                poPDefn->SetType( GMLPT_Integer );
            else if( EQUAL(pszType,"Real") )
                poPDefn->SetType( GMLPT_Real );
            else if( EQUAL(pszType,"Complex") )
                poPDefn->SetType( GMLPT_Complex );
            else
                          "Unrecognised property type %s.",
                          pszType );
                return FALSE;
            AddProperty( poPDefn );
    return TRUE;
/*                           SerializeToXML()                           */
CPLXMLNode *GMLFeatureClass::SerializeToXML()
    CPLXMLNode  *psRoot;
    int         iProperty;
/*      Set feature class and core information.                         */
    psRoot = CPLCreateXMLNode( NULL, CXT_Element, "GMLFeatureClass" );
    CPLCreateXMLElementAndValue( psRoot, "Name", GetName() );
    CPLCreateXMLElementAndValue( psRoot, "ElementPath", GetElementName() );
    if( GetGeometryElement() != NULL && strlen(GetGeometryElement()) > 0 )
        CPLCreateXMLElementAndValue( psRoot, "GeometryElementPath",
                                     GetGeometryElement() );
/*      Write out dataset specific information.                         */
    CPLXMLNode *psDSI;
    if( m_bHaveExtents || m_nFeatureCount != -1 || m_pszExtraInfo != NULL )
        psDSI = CPLCreateXMLNode( psRoot, CXT_Element, "DatasetSpecificInfo" );
        if( m_nFeatureCount != -1 )
            char szValue[128];
            sprintf( szValue, "%d", m_nFeatureCount );
            CPLCreateXMLElementAndValue( psDSI, "FeatureCount", szValue );
            char szValue[128];
            sprintf( szValue, "%.5f", m_dfXMin );
            CPLCreateXMLElementAndValue( psDSI, "ExtentXMin", szValue );
            sprintf( szValue, "%.5f", m_dfXMax );
            CPLCreateXMLElementAndValue( psDSI, "ExtentXMax", szValue );
            sprintf( szValue, "%.5f", m_dfYMin );
            CPLCreateXMLElementAndValue( psDSI, "ExtentYMin", szValue );
            sprintf( szValue, "%.5f", m_dfYMax );
            CPLCreateXMLElementAndValue( psDSI, "ExtentYMax", szValue );
        if( m_pszExtraInfo )
            CPLCreateXMLElementAndValue( psDSI, "ExtraInfo", m_pszExtraInfo );
/*      emit property information.                                      */
    for( iProperty = 0; iProperty < GetPropertyCount(); iProperty++ )
        GMLPropertyDefn *poPDefn = GetProperty( iProperty );
        CPLXMLNode *psPDefnNode;
        const char *pszTypeName;
        psPDefnNode = CPLCreateXMLNode( psRoot, CXT_Element, "PropertyDefn" );
        CPLCreateXMLElementAndValue( psPDefnNode, "Name",
                                     poPDefn->GetName() );
        CPLCreateXMLElementAndValue( psPDefnNode, "ElementPath",
                                     poPDefn->GetSrcElement() );
        switch( poPDefn->GetType() )
          case GMLPT_Untyped:
            pszTypeName = "Untyped";
            break;
          case GMLPT_String:
            pszTypeName = "String";
            break;
          case GMLPT_Integer:
            pszTypeName = "Integer";
            break;
          case GMLPT_Real:
            pszTypeName = "Real";
            break;
          case GMLPT_Complex:
            pszTypeName = "Complex";
            break;
        CPLCreateXMLElementAndValue( psPDefnNode, "Type", pszTypeName );
        if( EQUAL(pszTypeName,"String") )
            char szMaxLength[48];
            sprintf(szMaxLength, "%d", poPDefn->GetWidth());
            CPLCreateXMLElementAndValue ( psPDefnNode, "Width", szMaxLength );
    return psRoot;
 * $Id: gmlpropertydefn.cpp,v 1.2 2004/01/19 16:54:44 warmerda Exp $
 * Purpose:  Implementation of GMLPropertyDefn
 * $Log: gmlpropertydefn.cpp,v $
 * Revision 1.2  2004/01/19 16:54:44  warmerda
 * added logic to capture field types
 * New
/*                           GMLPropertyDefn                            */
GMLPropertyDefn::GMLPropertyDefn( const char *pszName,
                                  const char *pszSrcElement )
    if( pszSrcElement != NULL )
        m_pszSrcElement = CPLStrdup( pszSrcElement );
    else
        m_pszSrcElement = NULL;
    m_eType = GMLPT_Untyped;
    m_nWidth = 0;
/*                          ~GMLPropertyDefn()                          */
GMLPropertyDefn::~GMLPropertyDefn()
    CPLFree( m_pszSrcElement );
/*                           SetSrcElement()                            */
void GMLPropertyDefn::SetSrcElement( const char *pszSrcElement )
    else
/*                        AnalysePropertyValue()                        */
/*      Examine the passed property value, and see if we need to        */
/*      make the field type more specific, or more general.             */
void GMLPropertyDefn::AnalysePropertyValue( const char *pszValue )
/*      We can't get more general than string, so at this point just    */
/*      give up on changing.                                            */
    if( m_eType == GMLPT_String )
        /* grow the Width to the length of the string passed in */
        int nWidth;
        nWidth = strlen(pszValue);
        if ( m_nWidth < nWidth )
            SetWidth( nWidth );
        return;
/*      If it is a zero length string, just return.  We can't deduce    */
/*      much from this.                                                 */
    if( *pszValue == '\0' )
        return;
/*      Does the string consist entirely of numeric values?             */
    int bIsReal = FALSE;
    for(; *pszValue != '\0'; pszValue++ )
        if( isdigit( *pszValue) || *pszValue == '-' || *pszValue == '+'
            || isspace( *pszValue ) )
            /* do nothing */;
        else if( *pszValue == '.' || *pszValue == 'D' || *pszValue == 'd'
                 || *pszValue == 'E' || *pszValue == 'e' )
            bIsReal = TRUE;
        else
            m_eType = GMLPT_String;
            return;
    if( m_eType == GMLPT_Untyped || m_eType == GMLPT_Integer )
        if( bIsReal )
            m_eType = GMLPT_Real;
        else
            m_eType = GMLPT_Integer;
 * $Id: gmlreader.h,v 1.9 2005/01/27 04:05:35 fwarmerdam Exp $
 * Purpose:  Public Declarations for OGR free GML Reader code.
 * $Log: gmlreader.h,v $
 * Revision 1.9  2005/01/27 04:05:35  fwarmerdam
 * added ParseXSD
 * Revision 1.8  2004/01/19 16:54:44  warmerda
 * Revision 1.7  2003/05/21 03:48:35  warmerda
 * Expand tabs
 * Revision 1.6  2002/03/06 20:08:02  warmerda
 * Revision 1.5  2002/01/25 21:23:21  warmerda
 * handle IGMLReader destructor properly in gmlreader.cpp
 * Revision 1.4  2002/01/25 21:17:34  warmerda
 * provided IGMLReader destructor implementation
 * Revision 1.3  2002/01/25 20:38:01  warmerda
 * added prescan and resetreading methods
 * Revision 1.2  2002/01/24 17:39:08  warmerda
 * added xml serialization and geometry support
 * New
#ifndef _GMLREADER_H_INCLUDED
#define _GMLREADER_H_INCLUDED
#include "cpl_port.h"
#include "cpl_minixml.h"
typedef enum {
    GMLPT_Untyped = 0,
    GMLPT_String = 1,
    GMLPT_Integer = 2,
    GMLPT_Real = 3,
    GMLPT_Complex = 4
} GMLPropertyType;
class CPL_DLL GMLPropertyDefn
    char             *m_pszName;
    GMLPropertyType   m_eType;
    int               m_nWidth;
    char             *m_pszSrcElement;
public:
        GMLPropertyDefn( const char *pszName, const char *pszSrcElement=NULL );
       ~GMLPropertyDefn();
    const char *GetName() { return m_pszName; } const
    GMLPropertyType GetType() { return m_eType; } const
    void        SetType( GMLPropertyType eType ) { m_eType = eType; }
    void        SetWidth( int nWidth) { m_nWidth = nWidth; }
    int         GetWidth() { return m_nWidth; }
    void        SetSrcElement( const char *pszSrcElement );
    const char *GetSrcElement() { return m_pszSrcElement; }
    void        AnalysePropertyValue( const char * );
/*                           GMLFeatureClass                            */
class CPL_DLL GMLFeatureClass
    char        *m_pszName;
    char        *m_pszElementName;
    char        *m_pszGeometryElement;
    int         m_nPropertyCount;
    GMLPropertyDefn **m_papoProperty;
    int         m_bSchemaLocked;
    int         m_nFeatureCount;
    char        *m_pszExtraInfo;
    int         m_bHaveExtents;
    double      m_dfXMin;
    double      m_dfXMax;
    double      m_dfYMin;
    double      m_dfYMax;
public:
            GMLFeatureClass( const char *pszName = "" );
           ~GMLFeatureClass();
    const char *GetElementName() const;
    void        SetElementName( const char *pszElementName );
    const char *GetGeometryElement() const { return m_pszGeometryElement; }
    void        SetGeometryElement( const char *pszElementName );
    int         GetPropertyCount() const { return m_nPropertyCount; }
    GMLPropertyDefn *GetProperty( int iIndex ) const;
    int GetPropertyIndex( const char *pszName ) const;
    GMLPropertyDefn *GetProperty( const char *pszName ) const
        { return GetProperty( GetPropertyIndex(pszName) ); }
    int         AddProperty( GMLPropertyDefn * );
    int         IsSchemaLocked() const { return m_bSchemaLocked; }
    void        SetSchemaLocked( int bLock ) { m_bSchemaLocked = bLock; }
    const char  *GetExtraInfo();
    void        SetExtraInfo( const char * );
    int         GetFeatureCount();
    void        SetFeatureCount( int );
    void        SetExtents( double dfXMin, double dfXMax,
                            double dFYMin, double dfYMax );
    int         GetExtents( double *pdfXMin, double *pdfXMax,
                            double *pdFYMin, double *pdfYMax );
    CPLXMLNode *SerializeToXML();
    int         InitializeFromXML( CPLXMLNode * );
/*                              GMLFeature                              */
    GMLFeatureClass *m_poClass;
    char            *m_pszFID;
    char           **m_papszProperty;
    char            *m_pszGeometry;
public:
                    GMLFeature( GMLFeatureClass * );
                   ~GMLFeature();
    GMLFeatureClass*GetClass() const { return m_poClass; }
    void            SetGeometryDirectly( char * );
    const char     *GetGeometry() const { return m_pszGeometry; }
    void            SetProperty( int i, const char *pszValue );
    void            SetProperty( const char *pszName, const char *pszValue )
        { SetProperty( m_poClass->GetPropertyIndex(pszName), pszValue ); }
    const char      *GetProperty( int i ) const;
    const char      *GetProperty( const char *pszName ) const
        { return GetProperty( m_poClass->GetPropertyIndex(pszName) ); }
    const char      *GetFID() const { return m_pszFID; }
    void             SetFID( const char *pszFID );
    void             Dump( FILE *fp );
/*                              IGMLReader                              */
class CPL_DLL IGMLReader
public:
    virtual     ~IGMLReader();
    virtual int  IsClassListLocked() const = 0;
    virtual void SetClassListLocked( int bFlag ) = 0;
    virtual void SetSourceFile( const char *pszFilename ) = 0;
    virtual int  GetClassCount() const = 0;
    virtual GMLFeatureClass *GetClass( int i ) const = 0;
    virtual GMLFeatureClass *GetClass( const char *pszName ) const = 0;
    virtual int        AddClass( GMLFeatureClass *poClass ) = 0;
    virtual void       ClearClasses() = 0;
    virtual GMLFeature *NextFeature() = 0;
    virtual void       ResetReading() = 0;
    virtual int  LoadClasses( const char *pszFile = NULL ) = 0;
    virtual int  SaveClasses( const char *pszFile = NULL ) = 0;
    virtual int  ParseXSD( const char *pszFile ) = 0;
    virtual int PrescanForSchema( int bGetExtents = TRUE ) = 0;
IGMLReader *CreateGMLReader();
#endif /* _GMLREADER_H_INCLUDED */
