[Gdal-dev] ogr gml reader needs an update
Wed May 24 22:45:56 EDT 2006
Peter Rushforth wrote:
> Hi Frank,
> I have made the following updates:
> gmlreader.h
> -added m_nWidth class member to GMLPropertyDefn
> -added getter and setter for m_nWidth member
> gmlpropertydefn.cpp
> -modified member function AnalysePropertyValue() to set the m_szWidth
> member via SetWidth method in the case of a string value
> gmlfeatureclass.cpp
> -added code to set property definition width member to value of Width
> element found in .gfs file
> The system does create the correctly populated Width element in the .gfs
> file,
> but the m_szWidth member is ignored by the ogr2ogr system when it comes
> to creating the output layer.  Could you point out where I need to look
> to make
> that change please?
Peter,
I have applied your changes, and updated TranslateGMLSchema() in
ogrgmldatasource.cpp to apply this to the OGRFeatureDefn.
You can grab that change from:
   http://www.gdal.org/srctree/ogr/ogrsf_frmts/gml/ogrgmldatasource.cpp
Thanks for your contribution!
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
