[Gdal-dev] gdal_rasterize - can't make it work
Christopher Barker Chris.Barker at noaa.gov
Thu May 25 12:48:50 EDT 2006
> Maciek Sieczka wrote:
>> But nothing happens - when the rast.tif is displayed it looks
>> untouched.
Frank explained this, but I thought I'd comment. Drawing a raster image
from Vector data can be a very complex process. In particular, shape
files specify the shapes, but don't specify anything about how they
should be rendered. Perhaps it's useful to have a some simple defaults
to do this, but as a rule, if GDAL goes down that path, there will be an
almost endless list of new features constantly requested, and I don't
think that is (or should be) the goal of GDAL.
There are a lot of tools for rendering maps out there (most using
GDAL!). It's probably better to use one of them. One that does a
particularly impressive job is Mapnik:
http://mapnik.org/
There are lots of others.
-Chris
Christopher Barker, Ph.D.
Oceanographer
NOAA/OR&R/HAZMAT         (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
