[Gdal-dev] Google Earth Data retrieval
Ivan Lucena ILucena at clarku.edu
Thu May 25 14:28:06 EDT 2006
Hi Mateusz,
If Nikolai wants to put an option in his application that calls Google Earth to show the area of interest, it is just an automated way to use Google Earth. And Google encourage us to do that. I can't see any copyright violation. It's just a matter of creating a KML like the following and calls GE to show the Placemark (or polygon) with the image available at the Google server.
I am glad that you have raised the copyright question but maybe we should get in contact with Google and ask what then before investing more of our time in development.
Thanks.
<kml xmlns="http://earth.google.com/kml/2.0">
<Placemark>
  <name>Google Earth - New Placemark</name>
  <LookAt id="khLookAt639">
    <longitude>-47.84474593216702</longitude>
    <latitude>-15.75715197509273</latitude>
    <range>108.0773469140987</range>
    <tilt>-7.957063583552913e-006</tilt>
    <heading>-62.79871524526389</heading>
  </LookAt>
  <styleUrl>root://styleMaps#default+nicon=0x307+hicon=0x317</styleUrl>
  <Point id="khPoint640">
    <coordinates>-47.84474593216702,-15.75715197509273,0</coordinates>
  </Point>
</Placemark>
</kml>
-----Original Message-----
From: gdal-dev-bounces at lists.maptools.org [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Mateusz Loskot
Sent: Thursday, May 25, 2006 12:15 PM
To: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] Google Earth Data retrieval
Nikolai Vladychevski wrote:
> We
> will be using it for private use, just like we can use
> now Google Earth as standalone application.
But you will broke copyrights and licensing agreement using Google
images that way!
It's said, that you are allow to access those data only with GE, so
if you'll use third-party software not mentioned in the agreement, then
you obviously broke the agreement.
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
