[GDAL-DEV] ogr2ogr -f "ESRI Shapefile" - problem
Thu May 25 15:40:00 EDT 2006
abhay menon wrote:
> Hello List,
> recently was trying to extract shapefiles from an oracle database in
> batch mode
> it seem that ogr2ogr is not allowing to create shapefile more 168 in
> numbers.
> i gave a simple instruction through the command line in same folder but
> the operation was terminated by saying
> *"D:\batch1\xyz169.DBF file could not be created"*
> where as the xyz169.shp and xyz169.shx where created.
> also did the same by changing the folder name it was successfully
> created. so changed my logic in the batch mode operation creating
> temporary place and  moving it to the actual folder.
> I am puzzled by the fact that why ogr2ogr failed in creating the
> shapefiles more than 168 in the same folder. Is it a limitation of the
> shapefile or is it set nature of the DBF file that not more than 168
> number file could be created at one folder in one go??
Abhay,
3 * 168 is 504.  I suspect you have a limit of 512 open files at a time on
your system and that this has been hit with the 168's shapefile set and
a few other files (ie. oracle connections).  I imagine you could invoke
ogr2ogr on one layer at a time and things would be ok.
Some operating systems also provide mechanisms to increase the maximum
number of open file descriptors.  I have no clue if or how this is possible
on windows.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
