[Gdal-dev] invalid/no projection information in output TAB format
	files
    Peter.Rushforth at statcan.ca
    Mon May 29 12:01:38 EDT 2006
Hello list,
I am using ogr2ogr to convert gml files to mapinfo TAB format, using
the following command option and syntax:
ogr2ogr -a_srs WGS84 -f "MapInfo File" test.map test.gml
The test.map and associated files are created, but the projection about
the layer is not set correctly and Mapinfo 7 crashes when exiting if the file
is not closed first, a concern.
When I go through MIF format, and then to TAB, the projection info is correctly
set in the TAB file and no problems with Mapinfo are encountered:
ogr2ogr -a_srs WGS84 -f "MapInfo File" -dsco FORMAT=MIF temp.mif test.gml
ogr2ogr -f "MapInfo File" test.tab temp.mif
So first converting to mid/mif, then to tab is an option, but is
there some way to skip that step?
Thanks for any advice,
Peter
