[Gdal-dev] ogr geometry intersection
Didrik Pinte dpinte at itae.be
Tue May 30 04:31:05 EDT 2006
Le lundi 29 mai 2006 à 11:27 -0400, Frank Warmerdam a écrit :
> Didrik,
> GEOS is used to implement the intersection so you would really need to
> dig into the GEOS (or perhaps even JTS) docs to find out how this is
> implemented.  Or, of course, you could experiment.
> My expectation is that an intersection between abutting polygons would
> result in either a linestring, or a multilinestring.  but I'm not too sure
> about it.
> Best regards,
Hi Frank,
In order to be sure of what's happening in intersections, i've build
some testcases to be sure of the results.
I've attached the python test file but here are the results :
surface overlap --> wkbPolygon intersection
border overlap  --> wkbLineString or wkbMultiLineString if it's not
straigth
mix between surface and border --> wkbPolygon intersection
point overlap --> wkbPoint intersection
no overlap --> wkbGeometryCollection intersection but empty
The last one is the only "strange" answer. All the other are the logic
behaviour.
So your expectation is confirmed ;-)
Didrik
Type: text/x-python
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060530/713f38f5/test_intersection.py
