[Gdal-dev] Mac OSX Framework builds
Howard Butler hobu at iastate.edu
Thu Nov 2 23:20:06 EST 2006
All,
I have incorporated William's patches for OSX framework builds into
CVS.  A bug tracking these developments can be found at <http://
bugzilla.remotesensing.org/show_bug.cgi?id=1297>.  A description of
OSX Frameworks can be found at <http://www.kernelthread.com/mac/osx/
programming.html>.  These developments shouldn't have any impact on
the normal build process, and they only (optionally) pertain to GDAL
on OSX.
To try it out, configure your GDAL tree with --with-macosx-framework,
and when you do 'make install', it will place the framework build in /
Library/Frameworks/GDAL.framework.  This build option should allow
you to work with GDAL inside of XCode in a way that it expects and
provide some symmetry for other open source projects doing the
framework thing on OSX like R and OSSIM.
Thanks for the detailed notes and patches William,
Howard
