[Gdal-dev] Re: Mac OSX Framework builds
William Kyngesburye woklist at kyngchaos.com
Thu Nov 2 23:28:33 EST 2006
Cool.  I'll try it out, and follow up in the bug track if there are
any problems.
On Nov 2, 2006, at 10:20 PM, Howard Butler wrote:
> All,
> I have incorporated William's patches for OSX framework builds into
> CVS.  A bug tracking these developments can be found at <http://
> bugzilla.remotesensing.org/show_bug.cgi?id=1297>.  A description of
> OSX Frameworks can be found at <http://www.kernelthread.com/mac/osx/
> programming.html>.  These developments shouldn't have any impact on
> the normal build process, and they only (optionally) pertain to
> GDAL on OSX.
> To try it out, configure your GDAL tree with --with-macosx-
> framework, and when you do 'make install', it will place the
> framework build in /Library/Frameworks/GDAL.framework.  This build
> option should allow you to work with GDAL inside of XCode in a way
> that it expects and provide some symmetry for other open source
> projects doing the framework thing on OSX like R and OSSIM.
> Thanks for the detailed notes and patches William,
> Howard
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those
least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
